sqqqqqqquuuuueeeeaaaaakkkkkkk
Car  E36 328
rite, i think its just the fan belt but if u start a car from cold an rev it an it squeaks tel me its just the fan belt??????
DONT rip the s**t outta me for this question or i will GIVE.YOU.BEATS
thanks ;)
if its the fan belt slipping then it wld get worse with lights and stuff on. im not mechanic but thats what mine did when the fanbelt slipped!
it was only wen i revved it a bit an it stopped after like ten seconds
any idea of cost for a new one an cud i do it myself?
If it sounds like a belt slipping it probably is.
try...Altenator drivebelt. You will know when it gets bad cos the battery will go flat.
I had this. Only sqeaked when cold and if you revved it.
I was told it was the harmonic balancer? Does this sound right? Jus had it fixed today. Hope I didnt get rippped off
Mine does the same, but also at some other half random times, but sometimes there seems like a pattern, spoke to mechanic, was told its just tensioning, if you happen to have a friend or good connection should only set you back a tenner or so.
yeh sounds like aux belt mine was the same a week ago got it done under warrenty was squeeling when i started after 20mps it stoped untill i started the car again...
all fixed now :D
