4 pots
Yep ABS still there, it doesn't come in that early and you can get a slight bit of a locking before the abs catches up, but its still there for when you need it.
yes abs works fine with 4 pots, as its the servo which does all the work.
lies. its the abs unit that does the pulsing. it has a series of valves in it. longstory short, they open and close to give the pulsing effect.
the abs will still work as normal with 4 pots fitted.:)
