medici999 Car Nissan 370Z Apr 11, 2007 #1 as above. happens in first gear, feels like the steering while is vibrating or shaking. any ideas? thanks
Russ. Car Audi TT 3.2 V6 Apr 11, 2007 #2 gearbox mount maybe on its way out? im sure edde or someone will be along soon with a more helpfull reply
medici999 Car Nissan 370Z Apr 11, 2007 #3 its only really in first gear when giving it some gas when pulling out. cheers
C clioGT Car megane rs & clio rsi Jul 4, 2007 #5 this is my problem after the coilovers. what can be the reason?
F f0xy Jul 4, 2007 #6 mines started getting worse with this...in second too....im taking the battery out later to have a look at the mount
F f0xy Jul 4, 2007 #8 was your joint between the cat and center section hanging down? mine is....so if yours was im guessing its the same problem?
C clioGT Car megane rs & clio rsi Jul 4, 2007 #9 mine is about suspension system.. I am sure of that... but i dont know exact problem...
E en035 Car RSTUNER'ED-C&B'ED RS-1 Jul 4, 2007 #10 there are camber correction bolts from k-tec, worth for trying.
Has Car RS 182 - Black Gold Jul 4, 2007 #11 clioGT said: this is my problem after the coilovers. what can be the reason? Click to expand... Have the coilovers been setup correctly? Most people dont bother to get them fully setup after being fitted. There nto like other mods where crutial setup wont effect it. If the toe/camber etc is all out it can throw out the feel of the car! Otherwise general things.... Tracking Wheel Balancing Exhaust Mounts Failing Engine Mounts Gearbox Mounts etc..
C clioGT Car megane rs & clio rsi Jul 4, 2007 #13 no setup done for it. we take them form the box and fitted directly. ive done height adjustment by seti t as the lowest position. that's all. what setup should have been set?
Has Car RS 182 - Black Gold Jul 4, 2007 #14 clioGT said: no setup done for it. we take them form the box and fitted directly. ive done height adjustment by seti t as the lowest position. that's all. what setup should have been set? Click to expand... That will be the problem. Even by fitting it with the most accurate way you can, you will never get it correct. A full geometry setup would be ideal but it gets expensive. Most motorsport companies will be able to do this for you. With it being low.... the usual tyre place wont even be able to get the tracking done. Toe/Camber checks etc.... A few people have had them setup in the Midlands somewhere for around £100. A good setup can cost as much as the coilovers themselves!
C clioGT Car megane rs & clio rsi Jul 5, 2007 #15 I'll try to find a place here in Turkey tomorrow. thanks for your help...
