Help, goin OTT
  80MPG BEEZA
got some major plans in the works, kinda need some help i understand people drilling holes in the chassis in attempt to save weight and it also looks cool in some places, like that white 106.
question is where can i drill holes out that would be safe? im thinking on placing cabon door cards in and in the rear and was going to drill holes out around the top section of door card, and all is getting sprayed
Not having bits is ligher than having them so forget carbon replacment cards etc.
Drill holes in the door handes is one idea.
There loads of good easy weight to be removed before you ever need to touch drilling the car.
  Qashcow
polycarbonate windows are a massive weight loss, reducing the wheel weight makes a large difference too. im new here and dont know what the spec of your car currently is, but what have you done gearbox/engine lightening wise?
  80MPG BEEZA
well the back is going to be completely stripped, is it possible to remove the bolt in the centre of the tyre well? door cars will only be 1-2mm thin to keep them light and stop it looking to garish, would remove roof liner but dont know how much it holds the sunroof shut.
really need to know how yozza did there front doors like removing window motors and if the window will stay up? just have basic handle and door pull
  80MPG BEEZA
its had all the air bags removed its currently in a slightly modded way but no major work
Just use some wood etc or superglue them shut esle go ploy carb anyway.
The tyres well bolt? The one in the center of the wheel I take it you mean ? If so nope that holds the driveshafts on at the fornt and the disk on at the back so definatly don't touch them.
Just remove the whole roof panel and use a none sunrooded one.
  80MPG BEEZA
yea the spare wheel well there like a bolt welded into the middle of it which sticks up looks like its welded to a plate which is welde to the floor?
how many queen head sheets am i looking at for the ploy carb windows?
  Qashcow
disc cut the boot bolt off lol.
one thing i did which not many people think about on one of my previous cars is when the gearbox is out or having new clutch fitted, either fit a lightened and ballanced flywheel or take the original to an engineering company to get it machined down a bit. cost me £30 an made a huge difference in acceleration. best £30 EVER spent lol.
never done the polycarb windows myself so wouldnt know how to get them done
if your after lots of small things that make a big difference, look and the bolts holding the car together. pain in the ass but possibly some weight loss to be had there?
  80MPG BEEZA
or i could remove the brakes they weigh a ton and i dont really need them i managed without to and from fcs lol
in a serious note i will angle grind the wheel well bolt off :)
  80MPG BEEZA
so u can go to the likes of an omex and get rid of all the immobiliser and stuff? just gotta keep indicators and the like
Yep simple wirin loom t ligh weight everyhting plus make it simplier no alarm or least bin as much as you have.
  Qashcow
hell yea, brakes are for pussies haha. u dont need power steering either, get rid of that too........or a roof infact, just cut it off an rit a cage to keep it from snapping the car in half :D
  CB600FS
Batman convert your car to a Morris 1000 stlye wiring loom.
Battery > Key barrel > Starter > Alternater > Earth
On a serious note stuff like rear wiper motor & arm? Bar in the boot for the isofix kids seats? rear seats? centre console, carpets etc
  ph1 172 Black
Get it remote controlled and that will take your own weight out of the equation. Gotta be more weight than bolt in tyre well!
  80MPG BEEZA
it takes alot of pulleys and stuff to make a life size remote controlled car i'll just leave my duds at home
  172 cup'd extreme
Remove magnex for an orbisound or yozzasport system
rear wiper mechanism, boot trim.
4 carbon door cards front and for the rear cards
remove the carpet and just have 2 mats
drive around with minimum fuel
change battery for a race one
fit a race fuel system with 20 litre tank like the Nana
  80MPG BEEZA
nana? are the race fuel systems like where you have the polished tank in the back?
your plans sound good jon :)
  80MPG BEEZA
gf's not keen on the plastic window scheme but it should look good hopefully get prices back soon :)
car accelerated by itself a little yesterday about 500 revs in 4th gear is it because its not mapped? or is my car a transformer?
M
mini-valver
You did it with your mind.....
Remove all carpets and sound deadening, Peperami has done it to his. Looks mint but I'm to much of a pussy to put up with road noise!
Pep
Living Dangerously
  M2,XJS,S1000RR
remember to take a s**t everytime you are about to go out in it, keep nails trimmed, hair shaved, lightweight shoes and clothing, leave your wallet and phoner at home, get a usb head unit as a ememory stick is lighter than cd's, only 2 front door speakers?
remove bump strips, smaller number plates, get an expression spolier instead of cup/dynamique spoiler, paint stripper the car, i bet theres a good amount of paint on it.
any good?
