strut brace
There only useful if
Yjere a gooid solid type
There fully bolted or welded to the shell
And the car has other suspension mods realy.
Danith
  GTi 7.5 pp/Mx5 nd2
just added one to my phase 1. dont reckon its gonna do sod all. just looks good. its OMP one which is just held by two self tappin screws at each side.
tight on the bonnet closing now tho! little dink in bonnet when i shut it near the passenger washer jet. this isnt right??
hasnt dented it cos the dink goes when bonnet is open.
Danith
  GTi 7.5 pp/Mx5 nd2
re align my bonnet?! maybe its that sound proofing stuff?
shall i remove an area of that?
  Clio 172 Cup
yes you might be able to lift your bonnet a couple of mill using the fixing bolts on the side you could try removinthe sound proofin dont tink that that will do it as its more likely to compress than dink your bonnet.
Danith
  GTi 7.5 pp/Mx5 nd2
cheers.
i just had a look. how do you adjust? i can only see the two nuts on underside of bonnet
