The RS inlet manifold
Da
Car  Less
I know the difference is the extra bore size, but how do you know which is fitted to your engine?
Would 1*2's generally be fitted with a RS version or is it pot luck?
look below the injectors, (under the fuel rail protector) it will have RS stamped on the inlet. Mine has one (182)
My late 172 had one, I believe they were introduced in 2004 so last 172's and then 182. Like said above, need to view under fuel rail cover.
You can just see it with a torch and inspection mirror if you stand on your head.... no need to remove the fuel rail cover. :)
You have to look carefully as it's hidden by the rail and injectors. My 2005 182 has one.
