clock problems
  • Thread starter Thread starter dannyh_17
  • Start date Start date
D
dannyh_17
hi guys my clock doesnt work on my mk2 phase 1 clio any ideas of how to fix it? cheers
probably need a bit more info mate, thats like ringing the doctor and going 'I'm I'll, whats wrong with me?'
lol since i bought the car the clock in the middle above the headunit isnt lighting up at all i have a alpine headunit but that hasn changed anything as it wasnt working before that will it be jus a fuse or is it more likely to be a bulb
sounds like a simple fuse issue, or the connection to the lcd display as come loose, ud probably have to get the dash off to check tho.
ok cheers m8 ill check the fuse in a bit any idea of the fuse number or just get the handbook out
ryt swapped the fuses and thats not solved the problem as the fuse i question also runs the stereo which works fine anythink else it could be apart from having to remove the dash
cant think of anything else, alost definately a faulty connection sumwhere, or a buggered lcd display, either way, that dash is coming off i think.
dont think those clios display the time above the headunit?? mines the same it only worked with the standard headunit where it showed the radio station information
