mmmm knocking on my ph1 172
  E39 530i
Noticed this the over day, knocking coming from the front part, at around 2,000 RPM. When sinking the clutch whilst driving there is a funny noise. What could this be. Talk to me guys
Thrust release bearing for the clutch I'd bet.
As for the knokcing check you drivshafts for play and then youe engine mounts and positon.
  E39 530i
Cheers edde I'll mention this to the garage. Not driving it as I cant be asked to cause more problems.
  Lots of Alfas
Could be the thrust bearing, common for them to dry up/wear out. Does the car whistle when the clutch is not pressed down? Otherwise the knocking could be your engine mounts.
