Register a free account today to become a member! Once signed in, you'll be able to participate on this site by adding your own topics and posts, as well as connect with other members through your own private inbox!
when the car is idling from cold it is making a lot of noise, more of a knocking/rattle noise tho.
need to check all the bolts are tight. but could it be anything else?
the silence after the CAT, when its cold give it a tap and listen for a rattle inside it. Dont do it after the engines been running coz you'll burn your hand!
what so if it rattles when i tap it, take the decat out and put the cat back in? no leave decat in place. will the centre section need replacing? yes, a cat/decat back exhuast will replace this and the back box. or will it be ok?
