decat noise
Car  b/g 182, meg tourer
when the car is idling from cold it is making a lot of noise, more of a knocking/rattle noise tho.
need to check all the bolts are tight. but could it be anything else?
the silence after the CAT, when its cold give it a tap and listen for a rattle inside it. Dont do it after the engines been running coz you'll burn your hand!
what so if it rattles when i tap it, take the decat out and put the cat back in? will the centre section need replacing? or will it be ok?
what so if it rattles when i tap it, take the decat out and put the cat back in? no leave decat in place.
will the centre section need replacing? yes, a cat/decat back exhuast will replace this and the back box. or will it be ok?
just checked what the problem
loose bracket between the decat pipe and the centre section :)
no noise/rattle when i tapped the centre section.
its all good
thanks a lot for your help :)
