Buying a MK2 Renault Laguna soon, so need to sell my MK1 Clio, but them are a few problems I would like to fix first.
The first problem is when the engine revs past 3000 RPM, it makes the most awful whistling noise, easily heard both inside and outside the car. It doesnt always occur, and occasionally it will occur below 3000 RPM. Any suggestions?
Second problem is the infamous humming noise, however I am certain its not a front wheel bearing, as it doesnt change with the direction of the steering wheel, and I had the nearside bearing changed recently anyway.
Third is a ticking like noise that sounds like its coming from behind the fans, only when the engine is running, gets a bit louder with the speed of the engine, I think it might be a belt but have no idea what to check.
Thanks alot for any help in advance.
