Paint restore
Car  307 hdi (powered by derv)
Following on from this t5hread http://www.cliosport.net/forum/showthread.php?p=3177486#post3177486
I also need to restore the colour on my dads car. It is meant to be a red astra but i keep looking out the window and seeing a pink astra.
I have just tried a patch on the faded paintwork with mer and a patch with t-cut. I will look in the morning and see what the results are like.
But in the meantime, which is the best way of restore the paint?
Is it just a case of using layers of polish to bring the shine and colour back or do i need to get some carplan coloured t-cut to do the job?
Hope you can help
The detailing novice.
A good chemical cleaner will cut through oxidisation I normally use Klasse All in One. You can use the physical abrasive cutting method on it too.
Then seal/wax. Avoid the colour magic type stuff.
What does that method entail? Sorry to be a pain
Klasse All in One uses chemicals type cleaning.
Physical Cut - would be a proper polish with cutting power - ie T Cut or Poorboys SSR's etc.
