power cap wiring
i have a power cap 1.0, 1800watt first austria amp and 2 jbl subs, i needed the power cap to power them correctly,
the way i wired it all was a join at the wire from the batter to a connector block with the power cap and amp wire in one connector.
someone told me i should have it wire to power cap from battery, then power wire from power cap to amp??
throw it in the bin
who every told you that you need the power cap needs beating with a big stick
well without the power cap i can only power one of my subs and when i plug in the 2nd one they go funny and pretty much underpowered....
i will also 3rd it.lol.id suggest a metal pole rather than a stick though,get a higher power battery and a stronger alternator
Failing that, second battery to power the ICE ;)
I have to concur with the others, capacitors are a complete waste of time. They do look nice though. Best bet is a higher powered alternator/battery.
