PLEASE HELP! re: power-steering resevoir
i've been an idiot and put WATER in the power-steering resevoir!
a mate of mine who's very mechanically minded says not to worry and it shouldn't do any long term damage as i didn't put a lot of water in.
But what do people think? will i be ok or should i get it bled?
i wouldn't, but pull the return pipe off the pas pump, turn the engine over by hand a good few times etc
ah ok, thanks mate. i need to drive 40 miles to nottingham. will it do it long-term damage? i'll check it over at weekend...
i wonder why my mate said i shouldn't worry? i hardly put any water in at all and as soon as i did it, i drained a bit out. what u think?
Pull the pipe off, start the engine and move the steering wheel from lock to lock several times. Then replace the fluid!
drain it and refuel.... i guess. but it was only a TINY amount of water and the fluid in the PAS resevoir doesn't appear to be too thin. r u a mechanic?
well i've seen PAS pumps fail for various reasons, a few of which have set on fire, your choice, but for 1hrs work is it worth risking?
quite embarrassing.... mistook it for the engine coolant. realised my mistake straight away and stressed like mad!! i've drove it 20mins to work and back and so far ok but don't wana cause long-term damage!
just had a look under the engine... looks complicated.
i've also got a "rattling" noise when the engine's running but idle. been advised the cam's wearing away? any ideas anyone please?
Your PAS fluid also lubricates the bearings on your PAS pump. It will be the same effect as topping your engine oil up with water. The pas fluid will go a creamy colour, the pump will collapse and you will also need a new PAS rack.
You can buy oil additive in any motorfactors to release them. For about £5 it's a cheap fix before ripping the head apart?
drain the engine oil, pour in 1.5L of cheap stuff and 3L of diesel (yes diesel!) plus an engine flush and take it for a spin for 20min giving the engine some load
drain it all out and whack in fresh good oil
*don't take me to court if your engine goes bang!
Shoulnd't use water for the coolent though anyway.
Unlikly to be cams wearing away as said chnage the oil etc first has the car been serviced with good oil and is one due etc?
edde;3253642[B said:
]Shoulnd't use water for the coolent though anyway.[/B]
why not? Coolant is just water plus glycol?
