S ste hutch Car 182 sport Oct 7, 2007 #1 how much should i lower my 182???????????? and wats the best springs 2 use????????????
clio_luke Car b/g 182, meg tourer Oct 7, 2007 #4 gazbenger said: 30mm? 60 sounds better Click to expand... 60mm is far too much for a 182. would look stupid and handle like a bag of shite. 30mm will be spot on. mine is around 30/35mm hope this helps
clio_luke Car b/g 182, meg tourer Oct 7, 2007 #5 ian 182 said: Eibachs and 30mm Click to expand... ^^^^
D deckitout Oct 8, 2007 #6 Does the Cup susp pack lower the car from a std 182, so is this lowered from a std set up, cup set up or are they both the same Thanks Phil
E edde Oct 8, 2007 #7 deckitout said: Does the Cup susp pack lower the car from a std 182, so is this lowered from a std set up, cup set up or are they both the same Click to expand... Both the same 182 cup is only 3mm lower and the cars tolerances are bigger than that.
