Tyre pressure question...(not the normal one)
Pep
Living Dangerously
  M2,XJS,S1000RR
When manufacturers state the tyre pressures should they be set without any weight on the car? i,e. the car jacked up on that corner whilst the air is put in?
Surely correcting the pressure with the weight on the car will give an innacurate reading?
  197
You can set your tyre pressures either with the wheels off the car, the car jacked up in the air, or with the wheels fitted normally to the car and they will all be the same.
Having the car's weight on the wheels does not affect the pressures inside the tyres.
Pep
Living Dangerously
  M2,XJS,S1000RR
ok cool, thanks for the replies.
I just wondered because at standard pressure my fronts still look low on pressure...
when you pump them up at the garage it tells you how much is inside , but i know visibly sometimes they look down :eek:
  197
Two questions for you:
1. What gauge are you using to meausure the pressures?
Don't rely on the gauge on your foot pump, or petrol station air line. Go down to Halfords or Machine Mart and get a reasonable pressure gauge (something like £5).
2. When did you set your tyre pressures?
Don't forget that with the recent drop in ambient air temperatures, if you set the tyre pressures a few weeks ago your tyre pressures may well now be 2psi lower because of the drop in temperature. Also, remember to set the pressures when the car has been stationary for a long time (so the wheels aren't warm) and also when the ambient air temperature is quite cool.
Pep
Living Dangerously
  M2,XJS,S1000RR
James, my dads got a decent compressor that I am relying on for the pressures, although I could treat myself to a proper gauge?
Also, I check all of the tyres every 1/2 weeks everytime i clean my car just to be on the safeside, like you say the lower temperatures have affected the tyres but i've topped them up accordingly.
