best way you can really check is, is get yourself a 12v bulb holder from a auto factors anything will do as long as you can connect wires to it. fit two male spade connecters to the other ends and connect it where the fuse plugs in. (this prevents you from keep blowing fuses,, more on this in a second)my dial illuminations and side lights are all out everytime i change the fuse it pops do you thiibk this is a likely cause i have tried removing the lights and what not and it still blows fuses
