cheers. is it easy to do?
Imo the above is pointless as the maxogen is designed to draw cool air in from where it sit's. I have fitted a cold air feed from my bumper grille and the only noticable difference was a hole in my grille, which I have now had to replace!!!
Now this was something I thought about while fitting my Maxogen, I had the bumper off, wheel off and arch liner out and thought what a fantastic idea.
Needless to say there is almost no room for said cold air feed and after the aluminium tubing I was using was bent and dented in such a way as that it wouldn’t provide any cooling benefit I had a hissy fit took it all out, and went to the pub.
I know others with more patience than I have fitted one but I’ve only even seen this with removing a fog light or cutting a mouse hole in the front grill and that’s not something I’ll be doing.
R2TR
R2TR
You did go to town:slap:
Turn wheel to left, remove couple of screws, remove piping etc job done
Helps if someone has fitted one before, cheers Mike![]()
