Snow foam wat do i need!?!?!
  • Thread starter Thread starter Clio_Craig
  • Start date Start date
C
Clio_Craig
Hi guys, a few questions regarding snow foam and the equipment
was just wondering if any one could help me out with
1. what kind of pressure washer is best
2. the bottle i need to use
3 And what kind of products can u mix with the snow foam mixture
To use a Snow Foam Lance you will need a consumer pressure washer with either a Karcher, Kew/Alto or Lavor connector. I use a Karcher K399 which I purchased reconditioned from ebay with a 1yr manufacturers warranty. ;)
There are two basic types of Foam Lance available, the std model with a 500ml bottle and the heavy duty version with a 1L bottle. I find that with the 1L bottle I don't need to rush around the car before it runs out.
There are three different types of foam solution on the market;
1/ Snow Foam - sometimes called Supa Foam, Super Foam or Wonder Foam (it is all the same).
2/ Snow Wax Foam - snow foam with added wax.
3/ Citrus Foam - Highly concentrated foam cleaner.
http://www.i4detailing.co.uk/acatalog/Foam_Pre-Wash_1.html
where can i get an autrobrite foam lancer from and how much is one?
so do you just mix the snowfam and warm water in the bottle? no car shampoo or anything
Get the lance from HERE!!
Mix the snowfoam and warm water for best results. I always started at the bottom of the car and worked up the way. No car shampoo needed but many people play around with different combos to see the results
Any PW will be fine B&Q have the Karcher 1010 for £40 at the moment
kool so from them i get 5 litres wiv it of snow foam :D:D
is the karcher 1010 good enough??
iv got that karcher, & i must be really thick but i cant get it to work :( i put tap on by the time iv reached the karcher the pipe has bursted off it,
& you can get that snow foam attatchment in halfords :)
im gonna go down halfords in a minute
so jay which karcher u got??
iv got the Karcher K 2.91MD its in halfords its a small 1 £130 i payed,
the connection o snow foam was £20 i think it was, didnt buy it as i was just after bucket & clay..
cheers m8 im gonna shoot down halfords later and see if i can get my hands on one
Cool,
good luck if you get 1 on tryin to get it to work by yourself,
mine's weird, all conections are connected, turn karcher on it goes off onits own as no water is pumped through, turn tap and bang pipe come's lose :(
f**k knos, probably just me doing it wrong, this is my first ever power wash and was excited to use it that i endedup using 2buckets in the end :( need to find a plumber now to get a outside tap :(
maybe someone else can share the light on how to use a karcher for dummies :D lol
youve only got 30days to return with argos though ye, after that you have to contact Karcher themselfs,
Will do, wont be cleanin the car until sunday now, allready done it 3times this week allready, im sure iv got a soft spot to keep it clean :P haha
im out there on sunday again to clean mine lol, first sign ov average weather im out there, wat car u got
This is the Karcher i got Craig,
mind the wheelie bin, i need to power wash it and re-do the wall for my mum :( ow poo,
Most Karchers will be fine I ran mine on a 7 yr old one. If you have a wickes there own make is made by Lavor which is also a very good make
The £40 i told you about in B&Q will do the job fine
cheers guys :D bring on B&Q 2moro and then need to order the stuff
so i need
HD Foam Lance 1L
snow foam fluid
and pressure washer
then i can snow the annoying people in my street
