misfire?
Car  Clio 200
when a went to get the exhaust fitted the guy at c+c said he thought there was a slight misfire. how do a get this checked? and what would the signs of it be
cheers
just seen your reply there mate,
is that a common problem with them? or could it be something as simple as a spark plug etc
im not mechanically minded but a few friends will be able to help me on it, is it best to get it on a diagnostics?
Can you tell if it just missfires when its idling or throughout the rev range?
Its worth checking the sparkplugs, check the ht leads, and injectors. If its a 172mk1 try changing the fuel filter.
seems just to be when idiling can hear it pop at the exhaust every now and again oh and its a ph2 172 other than that the car seems to run fine
Was gonna say, if its just the odd pop from the exhaust when idling thats normal.
ahhh, it happens hot or cold but can usually hear it when idiling, il see if i can get a wee video up to show it. just want to make sure its not missfiring but youve cheered me up a bit lol
Mine does this and has done since I owned it. I wouldn't worry about it though, I thought exactly the same as you as well at first.
I am still on the original exhaust and the car is now 5 year old with 36k.
theres the video - you can here it popping away just wanted to make sure lol
