has it been remapped?
Car  clio 182
was looking at a clio 182, and was looking through some of the documents and there was a receipt from superchips which cost the previous owner about £300, does that mean its been remapped? and if so how can i properly tell, increased revs?
thanks guys
could always try hitting the limiter(when its uo to temp of corse)and see if hits higher than 6850
Sounds like it; they might not have upped the limiter.
Give Superchips a call and ask?
Call the company up. They normally keep records of the car's registration and what has been done to the car.
Mine is variable, it goes from something like 5 as soon as you turn the key, then to 5.5 or 6, then to 6.5, then to the full whack. Not 100% on the first couple of steps, never having revved it that hard when it's cold! I do occasionally hit the 6.5 one though, when i misjudge how warm it is.
mines on a Y plate 2001 ph2
i think ill be checking again as im gonna look a numpty if im wrong
Not that i hit the limiter much anyway;)
mines all ways warm before givin it some and mines defo under 7k
Warm or hot? Mine takes a good 15 minutes of driving before switching to 7250. If yours stays at c.6800 all day long then perhaps there's something not quite right about it?
TBH the engine is so rough over 7k that it's really a moot point. Better to change up a gear and keep your fillings from falling out.
