1.2 16v mods
Car  black 3 door clio 1.2 16v
heya guy's since im keepin my clio for 3 years till i get my skyline on tha road i wanna make ir more fun to drive and a bit nippier lol so here are my plans
exterior mods
1. 16 inch light wieght alloys wid sum super sticky road legal tyres
2. lower 40mm on adjustable coilovers
3. powerflex bushes (had gr8 results on my last car)
4. carbon front strut brace (style and function)
engine mods
1. k-tec 200 cell sports cat
2. pro speed s/s exhaust system
3. modded airbox and k&n panel filter
4. i have a modded 4-2-1 manifold made ages ago
5. ecu remap (i get them quite cheaply to help mods work together)
brakes
1. uprated discs
2. greenstuff fast road pads
3. s/s braided brake line's
im not bothered about cost at all ! lol
What do the power flex bushes do? how much was the manifold and what sort of performance increase does it give you on the 1.2? ;)
exterior mods
Stick to 15" it suits the car better and handled better
I Had FK Silverline X with great results, make sure you get them set up properly
I also used these with great results. a bugger to fit though
Wont do anything for handling, i welded mine in to make it more functional but tbh didnt make that much difference
engine mods
Get a spare cat for it and cut it open and cut it for a home made decat, much much cheaper and better power gains
I got a good gain from a cat-back low down in the rev range
I aso used this combo and it worked well
Worth while if their cheap like you say
brakes
1. uprated discs
Brembo max were great on mine
Also fine for fast road use on a 1.2 16v
exterior mods
1. 16 inch light wieght alloys wid sum super sticky road legal tyres 16s will look good but 15's will handle better.
2. lower 40mm on adjustable coilovers - if you go for coilovers make sure you have them set up properly
3. powerflex bushes (had gr8 results on my last car) - if you liekd the result then do it again
4. carbon front strut brace (style and function) - style but not function. They are all carbon 'look' and pretty shocking. Go for an OMP and make sure you bolt it on.
engine mods
Personally would do none of this, would see very little gains.
brakes
1. uprated discs
All sounds good
