Your english is fine dudeloads better than some on here who decide to type in text speak :dapprove:
The ford focus rs had them on too. A used set from a fiat coupe 20v turbo isn't that expensive at all, but I don't know if they would fit.
Maybe worth giving Brian a PM, as he's running Brembo calipers on his 172.
porka 996 callipers are radial mount, so all you need is a bracket and the correct size disk!
good call ben,
I still have a front and rear set of 996 calipers from my VW days and have been looking at the feasibilty of fitting them to a clio.
It's either that or sell them complete as i still have the brackets, spacers etc.. for VAG's
Think the biggest stumbling block is the custom made brackets required as comp brake will provide pretty much any bell/disc combo required.
You could run 300mm discs aslong as the custom bracket was machined correctly.
But normally it's 312mm Disc under a 16" Rim on the VAG.
