Dash felt
Car  clio 182,ff + 1.5 dci
Does anyone on here know where you can get the felt type stuff that you can cover your dash etc with to stop glare??
And how much of a pain in the buttocks it would be to fit it all in???
Cheers.
Do a search for flocking companys, there are loads about.
Is flocking much different to Alcantara?
hello, flocking isnt a material, its nylon micro fibres, they are attached to a substrate/dash by applying adhesive then spraying the flock onto it. The best way is to use electrostatic equipement (which is what we use) which gives the best finish making the fibres sit at 90 deg. angles. This gives a alcantera like finish. The other way is to use a diy kit which used a 'puffer' bottle, very cheap and is no where near the same finish but if its cheap as chips your after then its ok :-)
If you need any advice feel free to give our company a ring on 07894 636 707
Hope this helps
Hope this helps
What sort of costs would it be to have the same done as Burp?
