induction kits
  • Thread starter Thread starter rikcambray
  • Start date Start date
R
rikcambray
Im thinking of getting an induction kit for my 01 172.Is there any particular make that are any good for the clio.Anything to avoid?
cheers
An ITG Maxogen is the dogs but its very expensive unless you can get one secondhand on the cheap.
For that money i'd get a BMC CDA.
But why is the ITG Maxogen supposed to be so good. It has no direct air feed, other than a feed from behind the headlight. It doesn't heat soak from the engine, but then neither does plastic. I can't work out why it is so much better than fitting a panel filter in the standard airbox and suplying a cold air feed to it.
I'm not saying it's not worth getting, I'd just like some reasoning as to why its so good say over the V6/cup airbox?
Compaired to an espace v6/ph1 airbox its probably no better than them other than it looks pretty. Although the filter on the maxogen is very funky, whether is makes a difference I don't know.
You don't really need a caf as long as you reasonably isolate the space behind the headlight as its a lot cooler than in the engine side of the bay.
id seen the bmc.did look pretty good.mite be the 1 to go i think.thanks for your help
