rev limiter in 3rd!
Car  black gold 182
what do your 182's hit in 3rd before the limiter kicks in?
im sure mine used to hit 90 in third but ive had a s/s sytem fitted and i was suprised when it didnt go past 85 the other day.
that normal?
105ish, but I believe the Ph1 172 is taller geared. This is at around 8'000rpm too, dont even know what standard limiter is set at lol
90!!? thats not a lot though is it?
Id have to go out and see. will try and remember on my way to work later and post up
I quite fancy a Ph1 Gearbox, are there any other differences appart from the taller ratios? Are they supposed to be stronger or anything?
You should manage 90ish, i'll bet it wasn't warm and was hitting the lower limiter at 6500rpm?
Weaker if anything and mechanical speedo drive.
