Cleaning your clio... (pressure washer Q)
Car  Arctic blue 182ff
Do many of you use pressure washers to clean you clio??
- what do i look for in buying one? rated bar? power?
- would like to get one that i can use that 'snow foam'...
- what are the pro's and con's???
thanks, Jack
I've used one for the last 10 years . Mines 120bar and 380 litres and hour flow . Plenty powerful enough for me as i use mine as pump to pump water out of a 25 litre fermenting bin .
Link to which one your bidding on , how much do you want to spend .
Aldi sell one rebranded under another name but it's really a Karcher but with a 3 year warranty , whereas karchers only come with a 12 month warranty .
ive got a karcher thats like 10 yr old....will it have the same fitment for a foam lance with karcher fitment? thought they might have changed the fitment over time?!
Use the karcher 2.19, if you get down to homebase theres 20% off all karcher power washers atm, somehting liek £35 for the 2.19.
100bar of pressure is fine for car washing, have 3 lances with it tho and also a foam lance.
Dont wash the car without one now.
Foam the car, wash off using power washer, wash the car using 2 bucket method and rinse the car off with the power washer again.
one bucket full of suds, one bucket clean water, wash using a washmitt, clean mitt using clean water. ets the dirt off the mitt beforee you get fresh shampoowater.
But then each time you rinse it, your putting it back into a dirty bucket...
^^^ Do what i do mate . First wash off any loose dirt with the pressure washer hooked up to the garden hose .Then i run a 6 foot length of hose into a 25 litre home brew fermenting bin filled with a couple of capfulls of Extreme body wash and wax shampoo and warm water . Then foam the car with high pressure foam , leave to dwell for a few minutes then continue with the 2 bucket method .
Hell of alot cheaper than these fancy foam lances ;)
Absolute genius! Love it.
