Exhaust alterations..north west
Car  Mk4 .:R32
I need my exhaust altering because it sits about an inch lower than it should do, and it looks a bit stupid. Any recommendations of places I could go to get it sorted?
Get to Top Gear in Padiham m8...near ish to you and I have gone for years without a prob...might need to go in with mine as the bracket snapped just as I was taking it back to the lock up
Chris
Cheers chaps!!
Is that just off the M65 Chris?
I'm not sure whats up with mine, I though it was the bracket, but when I went down to birchdown they mentioned I might wanna have it cut a re-welded because the flange isn't flush with the cat!!
I'd just get it on some ramps and take it all off and re-fit it mate. Take you time with it and leave all the clamps loose until you have it sitting perfect then tighten everything. You'll probably find that its slipped out of a spleeve on the piss slightly.
Depends if you can be arsed on not though ;)
Cheers chaps!!
my yozza exhaust is booked in at JP exhausts next week for some modification :D
yeah mate there is a place in burnley its called (d.c.m.s) and they specialise in custom made stainless exhausts so they got all bending equipment etc etc
Cheers chaps!!
You will see what i mean mate if you take it off, the flange welded to the centre piece has been done by a drunk irishman with a white stick!! I think it needs taking off, and re-welding!
