installing new cd player problems
Car  clio
hi all i have got to install a new cd player in an o2 authentique clio, i have never done one before so a few questions if any body can help i would apreciate it! is it the usual u shaped removal tool, what adapter will i need to get the new cd player to work or will it just plug straight in to the existing harness its a murphys cd - 7510? anything i need to know b4 doing this? how does putting a new cd player in affect the code requirements?
U shaped tool for removal, should be plug and play, will need adpators if your weanting to keep the stalk control function.
Won't need a code again unless you put the old one back in it.
so to clarify i pull old one out and insert new one it should function with no adapters but to get steering wheel controls to work i need an adapter?
yes mate! also not using an adaptor can also effect things like AC, dash lights, electric windows, auto headlights.... etc. an audio specialist told me that n he wasnt tryin to sell me anything either
not true it will be fine
only need an adaptor if you want to use the screen and steering controls
i needed a little ariel adaptor for my old pioneer one, dont know about others (think it was a pc97 or something along those lines)
if your having trouble getttin the new unit to push fully home then its probably wires in the way, i found that the wiring for the harzrad lights/door locks/rear screen was in the way. pull off that panel and you can manipulate the wiring round the side of the new unit to allow it fully home :)
should just be a plug n play resumming the wiring connections are the same, but if its a single DIN then it will just require a new cage to sit in, which you should get with the new HU
i plug and play them easy done,you will need a ariel adaptor through, if u want to use u steering wheel controls your unit has 2 be wot we call patch lead compatible, ie in the bottom corner of unit will be a blue female conection, u need to buy a £ 4.99 lead to go in there then a £ 29.99 lead to connect to the yellow or blue plug in the dash and jobs done hope this helps u mate ,
any ideas of the aerial adapter code? is the one above the correect one? ^^
