You wont need a 60mm spacer dunno if youoll even need one at all as long as its the right ET and PCD you may need something like a 10mm to miss the suspension at the rear, full lock will also be limited i think
9's !
....thats what my BBS are going to be after the rebuild...
youve got no chance of getting them in the arches unless you do some MAJOR arch work...im looking into it, and its looking like its another £700 bodyshop bill for that! ....otherwise have them sticking out the arches but its illegal :/
you can achieve the look though without going massively wide :/
oh, and im 99.9% sure hers arent 9j on the rear![]()
....9j will seriously stick out the arches so its up to you if you want to take the risk with the po.po.
best bet if you want a fit and play would be a 8j on the rear and 7j or 7.5 j on the front...
and as for spacers...i wouldnt bother.
...you can buy my BBS for £800![]()
lmfao!
..well depends on how wide your wanting to go.
i wouldnt go any less than ET43....even those might require 3mm spacers to miss the suspension..
but fitment wise your after a pcd of 4x100 and a center bore of 60.1
cheers mate btw whats PCD? will someone shed some light onto the correct profile sizes i will need to achieve a nice ph-fat look?
Pitch Circle Diameter = the diameter round the centre of the holes.
so what do you think is a safe 'ET' lol well anything fatter than my 17s/7.5" will do really, want it to look chunky, squat, fat err oops here i go agen.. lol what do people reckon to the borbet bs? only because its a cheaper option...
well what size you wanting to go for?
15's...16's?
...personally, i think a nice set of 7J ronal turbos would look sweet if your on a budget as theyre a smart euro proven set of rims. can pick them up for like £550 with tyres...as you can with the ATScups.
ahhh.
lauras got keskin KT5's on hers....theyre smart
...have a look, or ring up the guys at www.dubmeister.co.uk.....or look on Rimstyle.com
i personally wouldnt go any bigger than 16's if you want to have a heafty drop....id stick with 14's/15's and only go 16's if you found some die hard rims...
