Letting air go in tyres/letting tyres down
  Suzuki Ignis Sport
Whats the easiest and best way to let tyres go down?
I've pressed the little button thing inside the valve to let air down, but it stopped after a while, and hasn't fully go down...
Wts the best way?
  Evo 6, E92 320d
Are you planning on removing the tyre or just softening it enough to get the masking tape tucked behind the rim, if its the latter you shouldn't need to let it go completely down.
  Suzuki Ignis Sport
I will try sitting on the tyres 2nite, if not, i'll get my gf and my brother sit on it with me LOL
  Suzuki Ignis Sport
Well its not down enough yet, so need to let it down more.
  M2 Competition
Lol! Common sense dictates that if you sit on it, and roll it along while sitting on it and pushing the pin in, more of the air will come out.
I was joking about the chubby friends thing haz, 8 stone will be fine.
  Petrol Blue 182.
take em to a tyre place and ask em to remove them carefully as you wish for them to go back on?
every suggestion you're moaning about it being an effort, why are you offering these services if thats the case ;) ?
Pmsl - how big are these wheels ??
  Suzuki Ignis Sport
The satisfaction of a happy customer and great looking wheels is why im doing it!
But if the tyres don't go down when i sit on it, then off to the tyre place :)
As said, theres a tool we use at work that removes the actual valve from inside its rubber casing etc, air out in seconds. Then simply refit again and re inflate.
No need for new valves/ taking tyres off etc
  LY 182
buy a valve key - you can remove and refit the valves fine they dont need replacing
if you want to do the job properly you need a tyre shop to pop the bead on the tyres so you can mask them properly
