Can someone explain the principles of throttlebodies?
Car  172 cup
Noob question...
Can someone explain how exactly throttlebodies work? Is it simply a matter of getting more air and fuel into the engine for more power?
Also what does ITBs stand for?
Help apreciated :D
Internal throttle bodies.. i belive
Reason they work so well is due to the lack of bends in the inlet sytem, look at your standard one.. starting from the valves.. plennum is basically 180 degrees then 90degress from that to the throttle bodie then another 90 degrees to the induction pipe then god knows how many bends through the air box & cold air feeds where as the throttle bodies there are no bends at all air just go's striaght in :approve: .. if they wern't £2,500+ i would love to have a set
Am i right in thinking that the standard engine has one throttle body, whereas with ITBs the car has four...therefore giving much more fuel/air to the engine?......or am i being thick?
Yeah that's it mate
Standard inlet is about 70mm, throttle bodies are about 45mm i think, so 4 of those = a lot more air
It's defo individual. The power gains are due to the vastly increased area of air flowing into the engine and the reduction in flow losses (caused by bends, expansions and contractions).
Power gain is only half the story. ITBs will transform a car. The throttle response is as good as you will get because the inlet tract is so short and the butterfly valve is so close to the head (and therefore the cylinder). Great for track use. Plus the noise is insane.
No question though, for the same money (3.5k -4k) spent on a turbo project, you'd go faster, but NA (naturally aspirated) gives better response.
true. iirc one of the very few road cars to have ITBs are BMW M3s ??? anyone know?
plenum being the first itake part of the engine,the part where the tb bolts onto,where it says renault sport,the engine cover goes over it
They are 100% individual as theres an individual throttle body for each pot. In the simplist way its just more air = more fuel = more bang = more kick in the pants.
Turbo/Supercharger does exactly the same thing but in a different way, all engine tuning is about is increasing volumetric efficiency in one way or another every power mod as far as I can think has an impact on V.E. hence the power increase or even decrease. But as Point8 points out diferent methods give different characteristics so thats where the plot thickens.
Cheers guys. Any more info would be appreciated or is that basically it?
Also any links to external sites with more in-depth info would be great!
This is as cool as ITBs get IMO
2nd stage, or stand off injectors. Normally you have 1 injector for each cylinder plugged into the manifold. With ITBs, it's the same. However when you need more fuel than the injectors can deliver, you need bigger (or better) injectors. Another way of doing that is just add 4 MORE injectors that kick in at certain RPM/throttle.
This is cool :)
[youtube]GsKNbsDqEPs[/youtube]
I should add it's also a pretty bad fire risk
Cheers point8 that looks amazing lol.
1. Could the standard injectors be modified in anyway so that they can deliver more fuel? Is this a route many people go down?
2. Also I know theres no specific "route" to follow when tuning, but to get the most power via N/A, what do most people do?
Im guessing, exhaust (mani, decat, cat back etc), then air filter, then cams and remap/omex ecu, then bodies (obv get rid of the air filter), then where is the typical route to go from here without going mad, (or have i missed something)??
Cheers guys.
Cheers guys.
1. No. Buy larger injectors that deliver more fuel. Injectors are rated up to certain power outputs in laymens terms.
2. Higher compression, using forged pistons is the 'least mad' you could then go, but still very expensive unless you have the skills to fit them yourself. Then you're looking at all steel internals and even more wild cams to increase the revs and power, but then driveability may suffer. IMO, you'd be better off spending money on a limited slip diff when you're at the 220ish bhp mark.
Cheers for the info inferno. :star:
Sorry, as im a complete noob, what exactly is/does a limited slip diff do?
Almost worth it for that alone, imo. Last one I heard was a yellow 106GTi hooning it up a dual-carriageway. Sounded brilliant - and didn't half shift. :)
D.
Ahhh excellent. Obv not looking at one now, but it may be an issue in the future if i decide to get more power out of my car. So, how much are we talking for a limited slip diff, roughly? And where sells them?
EDIT, just seen them on yozzasport.
You dont need a limited slip diff mate.
First step you have to ask yourself is, do you want to spend thousands modding your Clio.
If the answer is yes, research into how much things cost and your budget and take it from there.
Thats what im doing atm. Just getting a feel for what things cost, what is worthwhile and gives the best bhp per £ etc. Im not saying i need a LSD now. ;)
At a guess you'd be looking at 4k for TB's. LSD's are about another grand excluding fitting i think.
Take into consideration also that you could probably buy a 2nd car with that 4k budget that would quite easily keep up with a Clio on TB's
