How hard is it to replace the clutch cable in a 172FF ?
I own a 172FF and away to replace the clutch cable pretty soon.
As its creaky/squeaky and going from a thread i posted on here http://www.cliosport.net/forum/showthread.php?p=4454972#post4454972 i think and have read the best solution is probably to replace it.
Next question is
How hard is it to replace the clutch cable and how do i go about it ? ?
Is it as easy as unhooking it at the pedal & gearbox end and pulling it through the bulkhead ?
Any tips would be appreciated.
Or if theres a guide to refer to even better :)
ive only ever done a 1.2 16v but the cable and route is similar iirc, i done it with the engine out which was really easy (as the engine was out anyway, i didnt take it out for the job lol) but i can imagine space will be your main problem, trying to get to it, but like i said ive never done on with the engine in, apart from that its pretty straight forward :)
i did a clutch cable and pedal on a mk 1 1.4rt...twas a reet bast*rd.will be easier if it aint snapped though...just cable tie the end of the new 1 to the end of the old 1 and pull it! it will pull the new 1 through!
no idea if there is a guide, its easy enough, just remove the airbox for easier access, maybe take off the passenger wheel too
Ok cheers.
Are there any clips behind the bulkhead sound deadoning at all i need to get to ?
