rs tuner arrived,help
Car  clio sport 182
just had my rs tuner deliverd,all that was in the box was a black box and 2 leads,is this correct,shouldnt there be a cd and instructions or something?if not then how do i get this working,how do i download the correct maps
What car do you have? Download the RS-Tuner Software from www.fastchip.nl you will need the driver as well. You can also download the user manual from the site! Try that and see how you get on!
Once you installed everything. Drop me a mail info@fastchip.nl and I'll tell you what to do step by step. Everything is described in the manual as well.
having problems with the driver,my pc wont find it and i dont have the disc,i downloaded the driver but theres nothing to install?
henk maybe stick in a little note with the box telling people to get the software and manual from fastchip.nl as this question above seems a regular occurance.
Manual and instructions are easy, any questions ask, dont forget to back up.
Good tip. Will do from now on.
hummm just pluged it all into the car but nothing comes up on my laptop,im confused,then again i am blonde,iv installed the driver,is there a desktop icon thats meant to be there that i have to open to use the tuner?
run the rs tuner program
plug it into your car, then make sure the ignition is on but the car is NOT running
in the rs tuner click connect and you shoudl connect to the ecu
the manual is very easy to understand..
If people could just go to the web-site first, then read the manual - there wouldn't be so much topics about this.
nhf partyboy, hope u manage to get it working !
yeah iv read the manual,i did back up my original,iv got it working now itsthe rst file i needed,is there a map i can get somewhere for the specific mods for my car?also tried to do a pa,what does WOT mean?as it wouldnt work
I don't know what WOT stands for but it means to start slowly and go quickly to third gear and than floor it and it will start loging!
make sure to start from low revs and don't stop untill u hit the limiter!
and let us know your bhp :)
ah rite ok,i did that but it didnt record anything,do i have to start while goin up through the gears or start it when i get into 3rd
go into PA mode, then go 1st 2nd 3rd and then floor it in 3rd from low revs.
Easy as pie
Do you need a laptop for a RS Tuner?
I was planning on getting one at the end of the month (pay day) but at the moment I haven't got a laptop.
unless you plan on having your desktop computer in your car with a long extension cable ;) yes is the answer to your question
If you can get your car close enough to the house to run a usb cable out the window to the car from your PC then there is no reason why you would need a laptop. Failing that just take the pc to the car!!
