karlktm Car clio 172 Sep 23, 2008 #1 how much firmer are the cup springs compared to the ff172 versions? also, how much lower are they?
E edde Sep 23, 2008 #2 nothing much stiffness wise 5mm front 7mm at the back from memory but tolerances mean that a ff can infact be lower.
E edde Sep 23, 2008 #4 karlktm said: pointless really swapping them then?! Click to expand... Yes. Although it does give you the ability to rave on about how much better it is even if its in the head more than real.
L Luke. Car Mental 172 Cup Sep 23, 2008 #5 edde said: 5mm front 7mm at the back from memory but tolerances mean that a ff can infact be lower. Click to expand... how does that work?? confused!
ditz Car LY 182 Sep 23, 2008 #6 i've fitted the cup springs for ff's for a few people now b16doe being one,, if you think about it, the cup, standard is lower 7mm than a ff. the cup is lighter than an ff imagine for a second that both cars were the same weight, fit the cup srpings to the ff its going to be 7mm lower right? now put all the extra weight of the ff in there too,, you are probably looking at 10 or more mm lowering it looked better to me,, noticable
E edde Sep 23, 2008 #7 ljb2k8 said: edde said: 5mm front 7mm at the back from memory but tolerances mean that a ff can infact be lower. Click to expand... how does that work?? confused! Click to expand... ride height is oficially 5mm front and 7mm back lower but the tolerance is 5mm + or - The normal 172 tolerance is is + or - 10mm
