headlight adjusters help standard - xenon
NOPE. The xenon ones level automatically so no need for manual ajustment.
WRONG! the adjusters are exactly the same. Where the signal to adjust comes from is the only differenece between xenon and non xenon. Xenons have a sensor on the rear beam, non have the wheel on the dash.
my headlights are miles out after i lowered it, does it mean they cant be adjusted? or is there a way to adjust them? there xenons btw
you can adjust the xenons, law states you have to be able to. there is a white plastic hex nut on top off the adjuster that you use. Do a search there is a pic on a very similar thread, somewhere!
