What size is this bolt?
Car  Audi TT 3.2 V6
Hi,
Can anyone tell me the size of the bolts marked with arrows in the pic? I presume its something i should be able to get off the shelf somewhere or do they need to be high temperature?
As you can see one is missing...well it snapped lol.
Thanks, Russ
Nah they dont need to be high temp regular is fine, I'v got loads of spare nuts and bolts for the f4r shame your not closer
If you disconnect the top part of the manifold you may be able to get grips on the one that has snapped off. Same happened with mine and managed to get it out and replaced easily.
Not to worry fella, im sure ill get hold of one sooner or later
ive managed to get the old snapped part out easily enough. Just looking for a replacement bolt
m6x1.0 thread and about 200mm long from memory?
any old bolt will do
That sounds about right, ill try and get hold of a few this week. im thinking some polished ones would look nice hehe
Was gonna say, never that long! Go to a machine shop and take one of them out when you get there, go in and ask for 10. C'mon Russ, keep up ;)
Far right bolt nearest the rad is slightly shorter than the rest so take a central one out if your going to get the right size by comparing
Yates' in Longton! Do head skims, black facing etc and I got some big end shells for my Corsa from there a couple of years ago.
I think they're still there :o
R Yates Engineering Co.
Telephone: 01782-837579
Address: 231 Scotia Road, Stoke On Trent, ST6 4EZ
Is what Google brings up, must have moved! Machine mart should do em though if not, or even B&Q!
Cheers lads, will try and get myself down there sometime this week and get some made up.
