Will Gearbox from 182 fit 172 Phase 1?
And the rartios will be shorter, but i doubt you would notice.
You could tap into the abs and use the OEM as your trigger wheel, work out how many pulses it fires in one turn of the wheel then convert that in a signal to power your speedo, you can buy a adjustable signal conversion unit to calibrate the rate of impulses to MPH.
Would need to cambridge math though.
Sweet yo, BenR got mine working using a convertor, took a bit of math but did it in the end!
