Spluttering @ Start-up
Car is clio mk1 RSI
Got a slight problem. when the engine is cold or has been stood a while, i go to start the engine it runs as it should and revs up as normal.
The problem is when i come to set of, I add accelleration and it chokes and splutters. leave it a couple of seconds give it a couple of revs and it ok.
Also noticed the revs can be a bit jerky when accellerating
plugs and leads have been changed, what can i try next
Could be a fuel problem, are you running the tank close to empty? fill her up with high octane and give her a blast to see if you can clear anything? might be worth a try
Car is clio mk1 RSI
Sounds exactly the same as my problem mate, have you had it diagnosed? My manifold/CAT ring was broken so have replaced that but ultimately hasn't fixed the problem. Next on the list is a new O2 sensor as that's what Clip threw up as the problem...
