nah theres a few who stayed here after 'upgrading' from 1*2's
just not as much modding of them on here.
Any1 managed to get a cold air feed from the front bumper on the 197
The induction point on our SE X85's is on the front bumper of the car - depending on the aero package its either just above the front splitter or between the grills on the flat of the bumper itself.
The rad is relocated 110mm over from its standard position to allow for this feed, oil cooler hoses etc. etc.
M
see, other advantage is no fog lights on the racers
icarus that induction set up looks fantastic! Where would someone source such a thing? Not that I am going to be doing it anytime soon
It's all made from Renault components, although some we had modified in house. The airbox is a standard Clio Cup/Megane Trophy airbox which we have modified to run as an exposed flat panel filter airbox due to issues with feeding an enclosed box effectively - on the standard X85 Cups the airbox/rear of the headlight assembly actualy forms a stealth inlet air restrictor.
The airbox sits on a steel plate which in turn mounts to the engine mount and the inner wing. Unlike a standard Clio Cup the gearbox breather on the BPM built SE X85s does not recirc into the airbox but rather has its own catch tank assembly.
The air filter itself is just an off the shelf flat panel green cotton filter.
The new airbox setup is based around an ITG AB80 WTCC airbox and is fed from the nose of the car.
M
Can ya make us one?
Race car only. On the road car you will need to move your battery and various other bits, lose the aircon and budge the rad over 110mm/take the angle grinder to your inner wing.
M
M
To make it media friendly here's a pic of the 2008 Spec engine in the BPM owned/run X85.
M
do they actually run it like that?
what an epic way to loose performance![]()
I'm sure it wont. These guys know what their doing!
Gaz, there is a part that needs leaving in place isnt there?
It's just a fact. That setup pictured will draw hot air off the rad. Never ideal.
How many induction/filtration systems have you designed and how many 1000's of KM's experience do you have with X85's then? That particular car has over 5 grands worth of electronics which are logging data from the engine package at upto 1000hz sample rate, ambient air temperature, airbox temperature and charge air temperature are all within a couple of degrees of each other, airbox pressure is constant and as close to baro as you'll get. No problem with that at all - the entire wheel arch is open next to it providing more 'cold air' than one would ever need.
Thats without even getting into the advantages of having it back in the bay aware from the crush/crumple zones that are all to likely to take some impacts in a 24 hour race.
To give you some idea we record accelerative G 100 times a second, mixing this with a few other logged values and some known constants allows us to calculate BHP. The car was producing exactly the same BHP at hour 23 of the 2008 Britcar 24hr as it was at Hour 2.4. That airbox design produces 2.1bhp more on average on that car than a standard Clio Cup airbox installation and thats not a guestimate or a single dyno run thats the average increase over 3200KM's with that airbox vs 2130KM's with a standard Clio Cup airbox. The standard airbox inlet is 27mm away from the back of the main beam headlight cover in order to act as an inlet air restrictor.
Oh and for that record that car and BPM Racing - P1 in the under 2000CC Class at the Britcar 24hour and highest points scorers in the Britcar Production Championship.
I think you're confusing a none optimised design with a less than ideal design!
M
The fact that it makes X amount more power than the standard setup doesent say anything about the air inlet temps, or the optimisation of this particular design. It just seems completely stupid to put a big open IK there. Are you sure there isnt a piece missing and it has a proper cold air feed sorted? IMO a better solution would look similar to the DC5 IKs that have a caf mounted at the top of the bonnet.
Acoustic valve on the road car to avoid a CEL. No problem making a plug in module that will avoid lighting the CEL without the valve actualy being there.
We've thought about doing an aftermarket setup but in order to gain anything decent on the road car you need to move the battery. Total kit price would be getting on for a grand once all done so no one would buy it!
M
CEL? Mines in the shed. I'm sure i just unplugged the valve, plugged up the vac pipe which leads to the inlet. Was a long time ago, i'll look tomorrow
I've often thought a gruppe M type filter that the Ep3 CTR's have fitted could work well on the 197. With the inlet facing the rear of the bay, it could go straight into the filter, then pic up from the scuttle..... Less bends = less restriction?
