are these acceptable?
any1 recommend them or recommend not to get them due to s**t quality? are they good to go for!? will they even fit the 172?.... common guys!!
I dont see how they can be poor quality to be honest, just a chunk of metal with some holes in it!
as far as i know all 4 stud clio's are the same centre bore i think
should be fine,
only question is what wheels are you looking at using them with? you won't be able to go far past et37 without risking rubbing.
should be fine,
just keeping the standard 172 alloys, that should b fine shouldn't they?
i can't remember exactly the offset of them, 46/47 i think?
that would give you an effective offset of 21/22 which i am pretty sure would rub.
basically, the lower the et value, the further the wheels will stick out.
to give you an idea, i was running some wheels at et37. with 45 profile tyres they were fine but with 50's they would rub on a big compression.
ye they will be sweet pal, will look much better as well. the only thing you will need is longer wheel bolts!!
