is this the right gear box mount
The second one is for a clio 16v/williams (clio MK1s mate)
Not sure if the 172 is the same.......doubting it. My 172Ph2 certinally is very different
is yours the same shape as the first one or the seconed one?
i have a ph1 172
the first one looks similar to my 172Ph2 one, couldnt tell you if the dimensions were correct tho
Isnt the phase one dogbone differernt though?
get under your car and have a look to make sure
Neither are correct for the Ph1, byu it from Renault, they really are not that dear, or poly bush your old one? £35.00 plus vat to do that and never replace again?!??
Sean.
That's for a 1.4 16v, not sure if the one you require will be the same but should be similar.
listen to Fred (Yozzasport) and Sean (K-tec). First one is defo wrong (twisted one is for the later models) and when Sean K-tec says second one is wrong then it prob is...
