Request Lowered Clios on 15inch Alloys Pictures.
ForceIndia
  Gentlemans spec 200
Jon.L
  911 GTS & Macan GTS
everyone bad mouths apex springs nothing wrong with them in my opinion what so ever. far too many haters for some reason!
  rps13
i have them and absolutely hate apex springs.
ride quality is shocking and they ruin your handling.
Jon.L
  911 GTS & Macan GTS
but ride qaulity is shocking in anything lowered unless its prolnes or sport lines. spend 1k on coilies yes the handling will be awesome bt the ride quality will be just as harsh if not even harsher than apex. my apex handle very well on smooth surfaces, and lets be honest who thrashes it down bumpy country roads any way!
LOWER=HARDER its obvious!
  172 & RSi
Ride quality on coilovers is 1000x better than springs (I know, I've had both) because the shocks are matched to the springs therefore they absorb the bumps in the road etc. much better than just springs.
If you fit springs alone, its just like fitting harder, compressed versions of your standard springs, and unless you fit shocks aswell, your standard shocks will struggle to absorb the bumps in the road, and you will find yourself bouncing down the road, being able to feel every little stone in the road as if it were a crater and just generally being uncomfortable.
My coilies are down about 80-90mm and even at that height the ride quality is soooo much better than when I was on 60mm springs, looking back now I don't know how I put up with it.
If I was to do it all again, I wouldn't bother with springs and would save for some coilovers. Seriously can't recommend them enough to anyone wanting to lower a fair amount.
Just my 2p worth anyway...
BIFCAIDS
  340i M-Sport & 182
+1 on what you said, even when i had Koni springs and dampers it was alot ruffer than my coilovers
DrR
  VW Golf GTD
All look, mint, i need to lower mine
People quoting pictures GRRR :mad:
Coby.
  XC60-R.......V40-R
Go on then .... Down anywhere between 50mm-70mm I'd guess on Coilie's
  Bumder With A Buffer
Do you struggle with any scrubbage at the front over speedbumps Andy?
Last I went to castle mall m bloody exhaust was grounding out on the multi storey and mines only lowered 40mm!
Coby.
  XC60-R.......V40-R
Nope no issues in Castle Mall or Chapelfield :).... Did have problems at Riverside but now I've had the Exhaust Reworked I can now get in there too and I've lowered the front a touch since those Pics
Nice! Mine on 16's (I know not 15's but it will be soon :) ) You can see its not that low.. I think my old Magnex Battle Cannon was not great TBH... havent had any rubbing with the Yozza :)
Coby.
  XC60-R.......V40-R
Get it on Coilie's and 15's.... You know it makes sense :)
KW's and LEDA's for sale in For Sale Section :)
