clio 1.6 mpg ...
Depends how you drive it. If you don't go above, say, 3.5k revs then it should be pretty high (unless you have a fucked lambda sensor or something like that).
I have the same problem on my 1.2, though that gets driven hard :o When driving 'normally' though it still only reaches around 32, could be lambda sensor that needs replacing but don't take my word for it as I don't have a clue!
I have a 1.6 16v Megane mate, same engine. Only getting 26mpg. Sometimes even down to 22 and never above 29!
I have the habit of driving quite quick though as there are a lot of good roads over here. Normally change at about 6000rpm if i'm pressing on or if i'm just going into town about 4000rpm, peak rpm/torque is 3750rpm so i'm guessing stay below that to get the higher mpg!
Not checked it for a while, but my 1.6 8v was never great; usually around 30mpg. It is a 10 year old though so sensors might need looking at.
orite might not be something up then motorway i am gettin 42 max. i have a feeling a 2 litre wouldnt be much worse on fuel
My 1.6 16v gets between 35-47ishmpg, the latter on motorway journeys crusing at 70-80mph and the worst ive seen is about 32 after ragging it silly for an hour or so
SNAP! Apart from mines the 5 door version :o
I get the same sort of MPG aswel, but i do boot it everywhere lol. Mines never above 28MPG :approve:
