wilwood pads (dimentions)
  F4R'd ITB'd '92 cup racer
right these calipers
http://www.wilwood.com/PDF/fl104.pdf
will these pads fit?
http://www.carbonelorraine-motorsport.com/marques_etriers/e_wilwood_wilwood_dynalite_center_287.htm
from what i am reading the carbone lorraine pads are 1mm taller and 0.9mm less in width (not thickness) , surely that wont make a difference in fitting?
also i know the shape of backing plate is different, but i cross referenced against mintex pads for the wilwoods (here http://www.rallydesign.co.uk/product_info.php?cPath=562_1931&products_id=13948 ) and they are the same shape as the carbone lorraine's
can someone confirm it for me?
we run Mintex pads in wilwoods, so if the dimensions are the same......
by my investigation the mintex pads are:
4mm taller
0.9mm wider
same thickness
compared to the carbone lorraines
are they going to rattle around in the caliper due to the extra space?
and yet compare the carbone lorraine measurements to the actual wilwood spec sheet, the carbone lorraines are:
0.9mm narrower
1mm taller
same thickness
which would lead me to believe they shouldnt rattle around if the standard poly-e pads dont (or whatever they are called)
