Hubcentric spacers in 10mm or 15mm
I had FK on my 1.2 and they were perfect.
Never wobbled or had any problems and they come with longer bolts iirc
FKs fred, i have a set of 15mm coming up for sale when i swap for 10mm if you are interested?
jamie
i have 4 eibach 10mm spacers for 172/182 and simular models and another set of 4 10mm that will fit 197 and all mk3 i asume. hubcentric btw
any1 intrested?
Ive found that forge motorsport in glos make them and curtis from powerstation is getting me a set to look at and try and if all well with them should beable to get a real good deal on a set if anyones interested.
FK 10mm hubcentric have been discontinued, so its either 13mm hubcentric + buying longer bolts, or 15mm hubcentric bolt to the hub, wheel bolts to the spacer
£50 a pair
Ah so it doesn't make a difference that they say year 1990-1998? Thanks mate.
No it doesn't, as little by as its for your mk2 Clio and not the mk3. They're 60.1mm centre bore, 4x100mm PCD x 10mm thickness, non hubcentric spacers which I would be my first choice as it leaves very little of the hub spigot to engage in the wheel. I used 10mm hub centric and ground down the hub spigot by 5mm to allow the fitment of these.
Thanks mate, appreciate the advice, will get them ordered up now.
