Acoustic  ; meaning something to do with sound/noise ...
thats rubish its not about just making noise at all.
it makes noise due to the air flowing over the valve itself so its porpose is to allow more air flow at higher revs where it needs more cold air at and higher air flow.
the fact that it closes at low revs means it also works at the other end of the scale say normal driving. lower speeds ect to 1. be more economical and 2. it saves the ecu doin so much work in the area of working out fuel to air ratio's. oh also hence the Acoustic Valve.
valve
Noun
1. a part attached to a pipe or tube which controls the flow of gas or liquid
2.
Anat a small flap in a hollow organ, such as the heart, that controls the flow and direction of blood
3. a closed tube through which electrons move in a vacuum
4.
Zool one of the hinged shells of an oyster or clam
5.
Music a device on some brass instruments by which the effective length of the tube may be varied [Latin
valva a folding door]
valve (v
lv)
1. a. Any of various mechanical devices that control the flow of liquids, gases, or loose material through pipes or channels by blocking and uncovering openings.
b. The movable part or element of such a device.
2. Any of various structures that prevent the backward flow of a body fluid, such as blood or lymph. Valves in the heart, veins, and lymphatic vessels contain flaps (known as cusps) that close in response to pressure created by the backflow of fluid.
3. One of the paired hinged shells of certain mollusks, such as clams and oysters
