smoke when i hit 5-8k any ideas?
  Ph1 172 & meg 225 lu
when people follow me i cover them in a blue/whits smoke at high revs, think its over fueling but not sure, any other ideas what it could be?
think i may have a custom map to try and sort it
  C63 AMG, F430 & 172
Blue smoke is oil, you would have to be running super rich to get smoke all the a way through 5-7k!
Engine using oil?
  2016 Audi RS3
Overfuelling would show itself as fairly dense black smoke, white smoke with a blue tinge is most likely to be oil.
Ben
Engine using oil?
no more than any other car i've had air fuel ratio dropt to 12 just after 5k on my r/r printout so i was thinking the rs tuner map is making it over fuel?
  M3 Touring
Its a very big poof of white/blue tinted smoke at high rpm, full throttle...
Smells like unburn fuel when I was behind you :S
need a map then to make the most of the unburnt fuel, might get more bhp at high revs :rasp: no point in letting it go to waste
  ValverInBits
it's been said a million times, but the 5k kick is not the VVT cam timing.
anyways, my 172 burns no oil at all. Not a drop ever. So how much is yours actually using?
When did you apply the RS tuner map? Is it custom or off the shelf map?
i put less than a quarter of a litre in between oil changes every 3-4 months if i give it plenty of stick but if i drive carefully i dont use a drop of oil
