Cleaning throttle body
Car  Gentlemans spec 200
I've got the sticky throttle on the ph1. I've replaced the throttle cable, so i'm going to remove the body tomorrow and give it a good clean. Whats the best thing to use, carb cleaner i'm guessing?
Carb cleaner..
WD40..
Petrol/white spirit..
Give it a good spray and all the gunk should come off, it is only dirty oil
you also need to get a new gasket for the throttle body as they are paper ones and not the reusable ones as on the ph2 iirc
Brake Cleaner, Degreaser, Paper Towels, Anything really as said it is just light grime etc.
