Phase1 172 3pin connector on throttle body and alternator help
Car  RB 182
Does anyone know where I can buy it with the pins or what to ask for at Renault as they're usually funny if I'm either not precise or have the chassis number
Also I'm wiring up the alternator and can only work out there is only two wires positive (to battery/starter) and a small two pin plug that only seems to have one wire - to the battery light I think?!? ...is that it? I thought there were more wires
Any help appreciated
so I can just ask for a throttle position sensor plug at renault? will they sell me just a plug? - thanks for the help
I doubt it, they will try and sell you the whole loom. best try a breakers, a lot of Renaults use that same plug.
You should be able to buy the marelli plug for the stock TPS. Maybe not from renault but should be doable.
Yep thats right. Battery cable (the big one) and a small wire fr the battery light, No more, no less
Bolted to the engine so its earthed already
